400ex CC Tires - 20" or 22"
I will only use 20" tire on a motocross track or sand. My 22" RAZRS will go over anything. When I was using 20" tires in the woods I would bottom out and get stuck all the time. I dropped to a 14t front sprocket and it runs the same as when I was using the 20" tires.
I highly recomened 22" RAZRS for all out woods racing!!!
We do primarily desert XC riding, and run Holeshot XCT's front and rear (22" rear/23" front), on both a Warrior and 400EX. The extra ground clearance in nice, especially on the 400EX which has a kind of low rear end to start with. You will notice the extra height when cornering, and will have to lean more to counteract it. The one place Holeshots are worthless is in deep sand, like the dunes. They just dig nice big square holes. In shallow or moderate sand, like you might find in a desert wash though, they are OK. These tires are virtually indestructable!
still the adjustment of the suspension will not help out in MX.... dude think about it...
santa's right, you probably don't want to have 23-22 on your quad for MX.... The compression adjustment isn't going to make as much difference as the tires... Plus your still gonna have some Power loss
