rubicon display flashing
Old May 23, 2005 | 12:41 PM
rubicon2's Avatar
Default rubicon display flashing
both my neutral display and my d1,d2,and esp are all flashing ,does anyone know what causes this as the bike is in slow mode and sputters in reverse with no power ????
Old May 23, 2005 | 01:52 PM
hondabuster's Avatar
How many times does it flash in a sequence?
This old thread gives the how to, on resetting and retrieving the codes.
rubicon codes
Old May 23, 2005 | 03:07 PM
rubicon2's Avatar
not sure ,but i will check ,it just started after i washed the bike ,maybe a connection needs to be sealed
Old May 23, 2005 | 04:43 PM
Yep, thats the most likely cause. Dielectric grease works well for sealing up those connectors.
Old May 23, 2005 | 07:34 PM
rdnred's Avatar
My Rubicon did this one day on me. But it was caused by someone turning the key off and on repeatedly. It was in slow mode and spit and sputtered in reverse too. I started turning the key off and on and it finally went back to normal. I guess i should have payed more attention to how many times it took of turning the key key on/off.. If you haven't already fixed it try turing the key on and off repeatedly about 6 times or more, i had mine in gear when i fixed it but don't know wehter you have to or not....
Old May 24, 2005 | 12:50 AM
RedGoblin's Avatar
YOUR ECM IS WET. It is located behind the tool box/storage compartment below the rear rack. Air hose and/or dielectric spray will do the trick. DO NOT do anything pertaining to angle/speed sensors etc. until you have checked this first. Also, make sure your regulator/rectifier is plugged in tightly, located beneath the right rear fender. Hope this solves your problem.
Old May 24, 2005 | 08:00 AM
rubicon2's Avatar
thanks for all the great advice but i have one question ,the dielectric grease should it be put on the outside of the connectors or should i disconnect them and put some on the pins also ?????
Old May 24, 2005 | 01:25 PM
MikeM's Avatar
the grease does not conduct electricity, but keeps moisture out and the connection from oxidizing
put it on the pins to keep them from corroding and loosing metal to metal contact
95wolv
Sep 27, 2024 12:00 PM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
exmotocrosser
Sep 26, 2015 08:18 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
