250r runs full throttle
Old Jun 30, 2005 | 08:52 PM
  #121
Hoopie's Avatar
Default 250r runs full throttle
I got the clutch cover and the clutch plate and springs off. It looks ok I guess but I dont really know what I am looking at.
  #122
2StrOkeFReaK's Avatar
Originally posted by: Hoopie
This is a bigger job than expected. Wish me luck! Remember your always welcome to come show off your skills! I will even buy the beer and food!
Right On, Bud Light. It shouldn't be too bad. Once you do it and it works you'll be able to do clutches on anything.
Just Dont force anything, or use a hammer and you'll be ok.
What part of the hood you in
Old Jun 30, 2005 | 09:11 PM
  #123
Hoopie's Avatar
I am on north 11 mile service drive just east of hayes. I have it all taken part but know I dont know how to put the 89 clutch update kit in? I will pm you my cell if you want to stop buy. I fell like I am so close but not quite there. I also need a new gasket for the clutch cover I torn it taken it off. I just took out the clutch plates to inspect them and the bottom blate has the metal peices broken off of it. I guess that means I need new clutch plates also. [img]i/expressions/face-icon-small-sad.gif[/img] I'm getting a sticker that says money pit for it when its done.
Old Jun 30, 2005 | 10:15 PM
  #124
I have guests over tonight.
Take a pic of the tabs on the basket, if they look like this [VVVVVVV] get a new basket. The bottom of the V is where the plate has worn into the basket. You can file that flat but it gets sloppy and you can feel it. Get those pics up tonight
I'll post back if you need it. Otherwise get a clutch kit, gasket set, and gear saver. Start soaking the clutch plates (fibers) in GEAR SAVER. They need to soak for a while before installing them. Maybe I'll come by when you got all the parts togeather. Get some coolant and a glallon of distilled water too.
Old Jun 30, 2005 | 11:50 PM
  #125
Hoopie's Avatar
I got the pics up once approved. the basket looks ok but the plates are trash. Whats the difference between Barnet, Tusk, or EBC clutch kits? The tusks are $30 and the ebc or barnet is $90?
Old Jul 1, 2005 | 02:32 AM
  #126
Yep ya definately need a clutch kit.. Get a Barnette.
List -O- Parts
Clutch Kit - Barnette
<U>Engine Gasket kit- Get a whole k</U>it (you'll use them)
GearSaver ?belray 80w White bottle says gear saver 3qt
Billet basket - if ya dont need it you can return it
If magic has premix coolant get it.
Get anything else I missed.................
Old Jul 1, 2005 | 03:36 PM
  #127
Hoopie's Avatar
I went to magic racing this morning and got all the parts listed below $310. After looking at the new basket I think mine may need to be replaced also because it has dents all along the side channels.
Old Jul 1, 2005 | 08:26 PM
  #128
WiCkEd500's Avatar
your clutch is definatly shot. if you got another picture looking down on top of the clutch basket, from the seat to the ground, i could tell you if you should replace it yet or not.
Old Jul 1, 2005 | 09:53 PM
  #129
Sorry if I left ya hangin, couldnt log on this morning.
If you are going to be using the new basket you will need a grinder to grind off the rivets that hold the gear onto the basket.
I have one if you dont.
Start soaking those fiber plates in gear saver, they cant soak too long.
Old Aug 3, 2024 | 08:06 PM
  #130
DRabbit2323's Avatar
Default Runs full throttle
I have a 2005 Kawasaki 250r and I’ve checked the carps I’ve checked the throttle it has gas going to it I never found any air leaks any where but when I start it it runs full throttle what else do I need to check for this to stop?
