What kind of Honda is this??
Check it out at the bottom middle of my picts... Once they get approved.
Just came by this ATV, anyone know the year, how to change the oil, and anything else I should know????
yea, this is a honda trx200 it was built in the days of the old 300 but before the recon was around. dont know anything about the oil but as far as problems, look at it like its a trx 300 just smaller (its bulletproof )[img]i/expressions/face-icon-small-wink.gif[/img] except for the drum brakes... darn drum brakes
yep looks like a 89-90 honda, but the trunk cover is missing. 200 cc engine, chain drive,2wd. purchased in 91 new and the son put about a million miles on it , was abused by everyone we knew. put new rings in it in 96 and a set of 26 "" wheels on the back and a new set on front ( dont remimber the size)and the wife drove it . kept up with the 450 honda's on the open road and in the muskeg. wife weighs about 130 lbs. could not keep a chain and sprocket on it in this area , muskeg and glacial sand. my brother in law still has it and drives it a few day each summer.good bike well suited to a small rider.
I have one of these its aTRX200 Type 1. Honda GN4 10w40 oil is correct oil. It has an oil screen at the bottom of the engine butyou have to pull the right side case. When I bought it last year I knew the previous owner had never cleaned the filter so I pullded the cover and after all that work the screen had know visible dirt. My recomendation is just change the oil regularly.
Engine
Ultra-reliable 199cc single-cylinder four-stroke engine is tuned for strong, useable midrange power.
Specially-designed piston and valve train offer a high degree of durability.
Rugged, smooth-shifting 4-speed transmission with reverse system.
Automatic clutch for easy shifting.
Reliable, convenient electric starter.
Maintenance-free solid state CD ignition utilizes an rpm limiter for added durability.
20mm piston valve carburetor offers superb throttle response and fuel mileage.
BACK TO TOP
Chassis/Suspension
Strong, exceptionally-durable steel frame.
Double-wishbone independent front suspension utilizes heavy-duty shock absorbers, tie rods, and ball joints.
50-degree steering angle offers a tight turning radius.
Rugged box-section swingarm and heavy-duty single shock rear suspension system.
Dual hydraulic front drum brakes and a mechanical drum rear brake.
Fully-enclosed rear trunk offers 55 liters of storage capacity and can carry payloads of up to 66 pounds.
BACK TO TOP
Additional Features
Special waterproof connectors throughout the electrical system.
Quiet, efficient muffler utilizes a USDA-qualified spark arrestor.
Key-operated, waterproof ignition switch for added security.
Snorkel-type air intake system.
Dual 25-watt headlights.
Comfortable, ergonomically-designed seat/peg/bar relationship.
Swingarm-mounted skid plate offers excellent chain and sprocket protection.
Washable, reuseable foam air filter.
2.1 gallon fuel capacity offers substantial cruising range.
Maintenance-free battery.
Standard tool kit includes tire pressure gauge.
Optional trailer hitch kit includes an oil temperature warning light and a maximum towing capacity of 507 pounds.
Six-month transferable warranty.
BACK TO TOP
Specifications
Model: TRX200
Engine Type: 199cc single-cylinder air-cooled four-stroke
Bore and Stroke: 65mm X 60mm
Carburetion: 20mm piston valve
Ignition: Solid state CD with electronic advance
Starter: Electric
Clutch: Automatic
Transmission: Four-speed with reverse
Driveline: X-ring sealed chain
Suspension Front: Independent suspension; 3.1 inches travel
Suspension Rear: Swingarm with single shock; 3.1 inches travel
Brakes Front: Dual hydraulic drum
Brakes Rear: Sealed mechanical drum
Tires Front: 21 X 7-10
Tires Rear: 22 X 9-8
Length: 71.5 inches
Width: 41.3 inches
Height: 40.9 inches
Seat Height: 29.1 inches
Ground Clearance: 4.7 inches
Wheelbase: 43.1 inches
Turning Radius: 7 feet 10 inches
Dry Weight: 410.1 pounds
Fuel Capacity: 2.1 gallons including 0.6 gallon reserve
Color: Red
Engine
BACK TO TOP
Chassis/Suspension
BACK TO TOP
Additional Features
BACK TO TOP
Specifications
Model: TRX200
Starter: Electric
Clutch: Automatic
Length: 71.5 inches
Width: 41.3 inches
Height: 40.9 inches
Color: Red
Thanks everyone! Anyone know where can I get a new trunk lid for it? [img]i/expressions/face-icon-small-happy.gif[/img]
house1
Aug 9, 2015 10:49 PM
