Crankcase oil
Old Jul 4, 2005 | 06:11 PM
monster88's Avatar
Default Crankcase oil
what type of oil should i be using for my crankcase? I have a 2001 400ex. There is no indicator or anything. Should i fill it half way 3/4 of the way? Can anyone help me on this? thanks
Old Jul 4, 2005 | 06:19 PM
TractorPacker's Avatar
Do you have a balloon?
Honda HP4 is a real good bet for the 400ex. When filling the oil tank I fill mine to the upper mark without the stick threaded in. I also look to see oil on the stick, run the engine , shut it off, then check it.
Old Jul 4, 2005 | 11:35 PM
monster88's Avatar
well i dont mean the oil in the oil tank. I use vasnine 10w-30 ATV oil in mine, so do i use that in the crankcase? Thats what i use in my engine.
Old Jul 5, 2005 | 02:42 AM
monster88's Avatar
need some help on this.. just use regular atv engine oil? same oil i use in the engine use in the crankcase?
Old Jul 5, 2005 | 02:44 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
It is a dry sump engine! The oil from the external tank, flows into the "crankcase".........it is all the same oil (engine and transmission). You check your oil level on the dipstick on the tank.
By all means get yourself an owners manual, it has pictures of where everything is! When draining, you drain both the tank and the cranckase (bolt on the bottom of the tank, and another bolt on the side of the engine), and replace the oil filter. You fill the tank, start the engine, then check it again and top it up. Check the level often!
Old Jul 5, 2005 | 02:45 AM
monster88's Avatar
k np [img]i/expressions/face-icon-small-smile.gif[/img] thanks. I need to get a owners manual for it your right. Thanks for the help.
Old Jul 5, 2005 | 02:54 AM
Red Rider
See my comments here, on oils. http://forums.atvconnection.com/mess...y&keyword1=oil
I think 10W30 might be light for very hot summer weather.
Old Jul 5, 2005 | 02:55 AM
monster88's Avatar
hmm ok. Im pretty sure its 10w-30.. i will check tomorrow on the bottle and see what it is. Its 2:00 AM here and i cant really think back[img]i/expressions/face-icon-small-tongue.gif[/img]
Scooter's Shop
Oct 9, 2015 02:09 PM
KSJOHN
Aug 30, 2015 08:15 AM
QuadCity
Aug 13, 2015 12:58 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
