'01 400Ex - Hard to pull clutch lever
Old Jul 23, 2005 | 03:23 PM
ThaChad's Avatar
Default '01 400Ex - Hard to pull clutch lever
Hey all,
I have a '01 400EX, as well as an '04 Z400...
The '04 Z400 has a really easy to pull Clutch lever...
The '01 400EX ALOT harder to pull the clutch then the Z400.
What i am curious of, is if i bought a new clutch lever for the Z400, and installed it on the 400EX would it make it just as easy to pull, or is there something else that is making the clutch soo hard to pull?
Thanks.
-ThaChad
Old Jul 24, 2005 | 11:09 AM
TheTurtle's Avatar
i wouldnt put a suzy lever on a honda that prolly wont fix your problem. my clutch isnt very hard but then again i dont have anything to compare it to. i would think it is either a bad cable or the honda just may have stiffer clutch springs, and you dont want to change that.
Old Jul 24, 2005 | 11:18 PM
whatwasthat's Avatar
Your clutch cable is a wear item just like anything else on your ex. It needs to be lubed frequently to maintain its smooth operation.
If it never has been lubed, I would go ahead and get a new cable.
Also, I doubt the suki cable will fit, i believe they have different ends on them? I may be wrong
Old Jul 25, 2005 | 10:55 AM
quad2xtreme's Avatar
After or when replacing the cable, get an EZ pull lever too. It makes a day of riding much more enjoyable.
/Jon
Old Jul 25, 2005 | 06:22 PM
ThaChad's Avatar
Do you have a link?
Or a brand and model?
Thanks,
-ThaChad
Old Jul 25, 2005 | 08:05 PM
C&D Racing
Call these guys. Basically, you will get a new perch and lever that has an extra hole drilled. It reduces the pull by 30%. I got mine from NACs but later saw them for less elsewhere.
You will be losing the emergency brake setup too. You should get a blockoff plate for the rear caliper if you don't already have one. You will also lose the clutch safety switch. Basically, you will be able to turn the starter over whether the quad is in gear or not.
/Jon
Old Jul 25, 2005 | 09:45 PM
400EXGuy070's Avatar
Maybe you need to adjust the clutch?¿?[img]i/expressions/face-icon-small-confused.gif[/img]
Reactant
Mar 30, 2022 02:08 AM
GregM
Mar 6, 2018 06:53 AM
brad wheeler
Jul 13, 2015 11:19 PM
tporath
Jul 11, 2015 12:31 PM
200es
Jul 10, 2015 09:09 AM
