any tips for changing front bearings?
Old Jul 25, 2005 | 11:09 PM
300exfreak's Avatar
Default any tips for changing front bearings?
anyone have any suggestions or tips on changing front wheel bearings?
Old Jul 31, 2005 | 12:06 PM
RHW's Avatar
RHW
I'm not too sure what kind of advice you are looking for? I just changed the both outter bearings on the front of my '99 300 4x4. It wasn't hard at all.
Old Aug 2, 2005 | 12:27 PM
robnhouston's Avatar
One good tip is if you're going to change the bearings then change out the inner and outer.
Unless you ran them dry, wet, etc, all they really need is a cleaning and repacking. You can buy a tapered bearing greaser at the auto supply stores. Clamp the bearing in this plastic cone thing and pump in the grease using a greese gun, forces grease into the rollers to ensure coverage.
Also always replace the seals(correctly). Probably #1 cause of bearing failure.
WilliamBos
Sep 30, 2015 08:08 AM
bonanza 440
Jun 26, 2015 10:01 PM
rcappie4
Jun 21, 2015 07:40 PM
rcappie4
Jun 7, 2015 02:53 PM
hoopduerr
Jun 2, 2015 09:01 AM
