Electric shifter problem
Old Sep 4, 2005 | 11:42 PM
sandpit's Avatar
Default Electric shifter problem
Originally posted by: reconranger
Lots of posts on problems with ES shifting! This is a system that doesn't show Honda's usual level of engineering refinement.
Any prospective buyers out there, take a lesson and just shift with your foot!
Mine has over 8300 kms and I have not had a bit of trouble with the ES.
I reccommend it to everyone who asks.
Old Sep 5, 2005 | 12:41 AM
ixRAZORxi's Avatar
I have to rock the quad to go from first to neautral sometimes. Other than that never had a problem. Except when my batterry cable snapped but it was an easy fix.
Old Sep 6, 2005 | 12:19 AM
hondabuster's Avatar
Originally posted by: Lighthouse
Well guys this problem has been beat to death many many time's and I have posted many times regarding this problem. I have two Honda recon es models and even though I work for Honda I still have a few problems with the ES. Now Please listen !!!!! the frist thing to check is the fuse under the seat, if the fuse is ok the at the frond of the unit by the steering post is the ECU unit. Disconnect the ECU and clean the connections both mail and female with a good electronic cleaner and let it dry, then use a good dialelectric grease to keep the connection from getting dirty again,that should solve any problem with the ES shifting on any of the Honda ES quads. I drive all the atvs that we have and I still like the ES quads the best (( just my opinion )) and not to start a fight with the standard shift people.
Please do NOT adjust the clutch unless it is slipping cause it has nothing to do with the ES shifting pattern of the unit
John
John, How come all my factory service manuals for Hondas say to do the clutch adjustment for es shifting problems? Its listed second in things to do..first is to check the battery voltage. Is the factory manual wrong? The clutch adjustment is a misnormer, its actually a linkage adjustment, from the shifting lever to the clutch pack, and if misadjusted effects the angle sensor. Try it out on a customers quad...purposely misadjust it...and see the shifting problems happen.
I find that most people dont do the clutch adjustment, very often or at all, and usually when theres an intermitent problem that comes and goes, or seems to be temperature related....its almost always the cure.
As I said, try the simple things first...its free, and doesnt require any special tools or knowledge. If that doesnt fix it, there are other steps which can be taken.
Old Oct 5, 2005 | 03:00 PM
baughbob's Avatar
With regard to the clutch adjustment (or rather linkage adjustment), how do you go about doing it?
Old Oct 5, 2005 | 04:33 PM
  #15
On the rancher and foreman the procedure is the same, ....im not positive about the recon, and someone correct me if im wrong, but on the forward side of the motor, youll see a slotted screw, and a nut. Loosen the nut, about 2 turns, but dont take it off. With a screw driver, turn the slotted screw, CCW, until you feel resistance....go back 1/4 turn, CW, and hold the screw stationary, while you snug up the nut. Done.
Old Sep 28, 2006 | 10:38 AM
  #16
Starino's Avatar
Good news!
Honda has put a recall on certian 2002-2005 TRX250TE Atvs for free replacement of the angle sensor. You can also get credit if yoru was replaced. The p/n number on the repair order has to be 38800-HP0-A11 or Honda code 786309.
So see your honda dealer today! I already got my refund!
Starino
Old Sep 28, 2006 | 11:23 PM
  #17
litegide's Avatar
I have had a 2001 rancehr 350 ES, A 2004 rancher AT (with the ES) a 2006 Rubicon (with the ES) and presently own a 2006 Rancher 350ES and have had ZERO problems with any of the electronic shift machines.
I like the electronic shift best, better than the AT/Auto or the Rubicon Auto because I like to shift - these machines had the best of both worlds with the ES and automatic.
I have always liked foot shift as well however the LED display is awesome. In addition I have a plow and in the winter have giant winter boots, the fwd/reverse over and over with a foot shift is no fun shifting w/your foot.
I have had many many foot shifted machines and they are good - we have a 2004 trx90 foot shift - it's great. Although, having owned 4 ES machines I have to say the ES is excellent! and will do it again.
Old Sep 28, 2006 | 11:35 PM
  #18
ForemanDan's Avatar
I have not owned an ES equipped quad, but I am sure that there are some (very few) out there that do have an occasional problem. But I am willing to bet it is only 5% (or less) of all ES systems out there that have a problem.
Old Apr 15, 2011 | 03:17 PM
  #19
Mark Henzi's Avatar
My Honda 250TRX TE (Eleictric shift) is stuck in 5th. The 1st gear light blinks. Cannot manual shift it into neutral. Dealer says they have to take the engine / trans off of the bike and crack open the trans case to diagnose. $450 + parts / lookin at $1000 repair! Help. Any advise that is given to me an works, I will send you a $50 gift card. Seriously.
Old Mar 21, 2015 | 06:56 PM
  #20
Dean Wood's Avatar
I also have shifting problems with my 2006 Rancher 350 ES I get a 5 flash code. I can cut it off and when I start anew it will shift into everything but reverse. Please advisse
