HONDA ATC200 WONT MOVE NEED HELP
Old Oct 8, 2005 | 12:35 PM
DINGERS1's Avatar
Default HONDA ATC200 WONT MOVE NEED HELP
I HAVE A 1983 ATC200 THAT I LENT TO A FRIEND TO GO HUNTING (NEVER AGAIN) HE WAS DOING NEUTRAL DROPS AND NOW IT WONT GO. IT SHIFTS THROUGH ALL THE GEARS BUT NO MOVEMENT. IS IT POSSIBLE THAT THE CLUTCH WAS BLOWN. ANY HELP WOULD BE NICE. THANKS JOHN
Old Oct 9, 2005 | 10:52 PM
maddmudder13's Avatar
when in gear and you rev in up does the engine bog down at all , or does it sounds and feel like its in nuetral?
Old Oct 10, 2005 | 06:48 AM
DINGERS1's Avatar
IT FEELS LIKE IT IS IN NEUTRAL.
Old Oct 11, 2005 | 10:46 PM
by chance, the gear shifter isent stuck up or down is it? when i shift my 200s into second gear it usually sticks down. but other wise it sounds like a clutch problem, maybe try adjusting the clutch or take the clutch cover off and see if you can see anything thats wrong.
Old Oct 12, 2005 | 11:10 PM
Doctorturbo's Avatar
GOT BOOST!
I don't know anything about your 200 but if it's anything like a semi-auto toilet seat 110 I had this is not good news. If you do neutral drops with this type of clutch it will break the ears off of the drum. A lot of aluminum parts in there. When this happens it won't go. Easy to fix though.
greg74
Sep 10, 2019 03:03 PM
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
momma's bike
Aug 6, 2015 09:49 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
DeFox500
Technical and How-To Articles
Jul 26, 2015 02:07 PM
