trx350 carb question please !
Old Mar 9, 2008 | 04:46 PM
  #31
Mike Z's Avatar
Default trx350 carb question please !
hey Tom, when you reply or create a post there is an button on top that says "http" with a chain icon image next to it. I had already uploaded some photos onto the web and when I clicked this button I just pasted the URL web address to where my photos were and it links to there now in the reply. My photos are on the TextATV Canada webpage in the members gallery. There might be somewhere in ATV Connection where you can do this as a member too. I bought an ATV winch (2500lb) from costco yesterday for 80$...has anyone installed one on these TRX350s? I'm also interested in a carb kit if you or Paul find one...
Mike
Old Mar 9, 2008 | 06:00 PM
  #32
ve7khz's Avatar
Sorry guys, I cant find any paperwork or email from the company I got the carb kit from. It was a company recommended to me by a poster in another ATV forum around August last year. It was either in Ontario or Quebec, and sold snowmobile, motorcycle parts mainly and some ATV things. Kit was $28 CDN and had everything needed for a rebuild including new jets, rod etc.
Good luck
Old Mar 9, 2008 | 06:10 PM
  #33
ve7khz's Avatar
Duh! Looked in my favourites and there it was...and here it is.
Also, check out atvcanada.ca forums. They are great as well.
http://www.royaldistributing.com/07/
Old Mar 22, 2008 | 02:01 AM
  #34
fixitfirstime's Avatar
it is the third slot, and it seems like the two of mine both liked 1.5 to two turns.
Not sure on the gap under the plastic cover...but do have a service manual...do you still need it?
Old Mar 22, 2008 | 02:10 AM
  #35
could all you guys that own 90-94 350d's post pics to either my myspace blog at,
http://blog.myspace.com/index....All&friendID=71283392
or at www.bikepics.com in the foreman fourtrax 350 area under the Honda atv headings.
I own two of these and would love to see these of yours, I have heard of them but never seen one.
HondaMechanic on this forum is someone who turned me onto the fact these even exist.
My 1988's are there as tjmztrx...
Old Mar 23, 2008 | 10:48 PM
  #36
trunner's Avatar
i'd love to show some pics of my machine, but do i have to become a member of myspace just to show pics? couldn't figure it out. anyways i have a pretty minty 1991 350D up here in manitoba canada. goes thru anything. fun machine but seems to spend a fair bit of time apart in the garage lately.
Tom
Old Mar 24, 2008 | 12:53 AM
  #37
Hey trunner,
Not sure about myspace, I started a registry there for anyone that wants to use it. You can go to bikepics.com and add a presence there. follow my directions in my last post to the 88 section to see ours.
Bob
Arlington, Tn.
Old Mar 31, 2008 | 03:51 PM
  #38
Caminuvik's Avatar
Just thought I would jump in this thread. I have 2 92 trx 350's. I also couldn't get the manual for 92- different story a couple of times. I got the earlier one and will check when I get home. I had some problems with carb also- check that the vent lines are not kinked. I am from the Kamloops area. Cam
Old Jul 23, 2009 | 07:33 PM
  #39
riverscout's Avatar
Default 05 trx 350
after 10 minutes of running the machine acts as if it has a fuel delivery problem,it starts to sputter and stall.I removed the fuel tank and drained it.removed carb bowl it appeared clean,checked the plug which looked fine. After some time like 1/2 hour or so it will start fine and run for another 10 minutes. Any help would be much appreciated.
Old Jul 25, 2009 | 09:09 AM
  #40
cw4usa's Avatar
Default 350 trx350fe carb question
Since we are jumping in here...I am new to the forum. First post...If I am doing this wrong, someone give me a clue. I have a '00 TRX350FE Four Trax ES Ihave started to have some issues that sound familiar in these posts. There is a drain line that is attached to the bottom of the carb with a 1 way valve in it. Mine drains fuel constantly unless I shut off the fuel supply from the tank. What is the purpose of the line and does it just hang free, or should the other end be connected somewhere. I cannot figure out what the thing does!
Thanks for your help
