400ex problem
Old Jan 2, 2006 | 04:10 PM
FrostyLemon's Avatar
Default 400ex problem
my rear axle has a lot of play in it when it is off the ground and when i turn it makes a loud clicking sound
any help would be appreciated
Old Jan 2, 2006 | 05:51 PM
Redripper's Avatar
the clicking noise: that may be normal, because every time i hear an atv with a chain it does that.
the axle: maybe the axle bearings are about gone.
Old Jan 2, 2006 | 09:20 PM
450rking's Avatar
i have a 400ex and the clicking sound is the chain and as redripper sed you probably need bearings try wiggling the back end
Old Jan 2, 2006 | 11:52 PM
the clicking sound only happens wgen i am turning
Old Jan 3, 2006 | 12:01 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I just had my bearings go out (they were 7 years old, so I got my moneys worth out of them). My first symptom was that clicking sound, and the second was that the chain went slack all of a sudden (because of play in the axle).
Best advice is to NOT RIDE THE QUAD until you have it diagnosed. Take my advice, and replace the bearings before the carrier and axle get totally ruined! I toasted mine and it cost me $700 to fix the damage (for replacements I went with an Lonestar 4 bearing carrier and DuraBlue axle). If you act before everything gets ruined, new bearings might run you a small fraction of that, as long as the carrier and axle are fine!
Old Jan 3, 2006 | 12:40 AM
URCRAZY's Avatar
Sounds like your bearings in the carrier. ANother way to figure it out, is to put the bike on the 4 wheels, and stand on the pegs, wobble the bike back and forth slowly. If it wobbles with you then they are most likely out. Or maybe just aloose carrier, check the 4 bolts on the swingarm where the carrier is.
Old Jan 3, 2006 | 02:11 AM
thank i bought the quad lats febuary and the guy i bought it off of said he just put new carrior bearings in
Old Jan 3, 2006 | 10:15 AM
Red Rider
If they were replaced recently, I wouldn't take that to mean anything. One source I know says bearings need to be replaced every year as part of routine maintenance anyway.
If you have been in a lot of dirty water, or other conditions that are detrimental to long bearing life, it may be time.........
Old Jan 3, 2006 | 10:29 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
I have been around a lot of 300ex's and 400ex's, and I have noticed that once the rear bearing carrier gets a little damaged, it tends to eat up the bearings really quick. On my old 400ex, it had a bad bearing carrier, and it would eat up a new set of bearings in just a couple rides.
Old Jan 3, 2006 | 03:27 PM
slomoe's Avatar
If you have play for whatever reason it will be bad on the bearings and you should replace them or like others have said they will go bad and it could be very costly. bearings and seals ar fairly inexpensive.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
