Curiosity on 450R rebuild intervals
Motox,
I have had my 450r for two years and I have a Hotcam Stage two in it. I have had no problems with it and I have not rebuilt it either.
A friend of mine got his 450r just after I got mine and he put a 10.5:1 piston in his last year. His original piston was still in great shape. He races a little flat rack and I don't race at all.
I trail ride alot and ride the Oregon dunes about 5 times a year, for at least 3-5 days each time.
I read a lot about having to rebuild the 450r often before I bought it and I think it was all just speculation.
#15
I change my engine oil every 12 - 15 hours and the clutch side every other time I change the engine. If I'm down at the dunes for 4-5 days, ridng 5+ hours a day, I don't change the oil until I get home. I don't think this is being lazy, it's just my maintenance procedure.I guess only time (and a lot of it I hope) will tell if changing your oil every 3-5 hours or every 12-15 hours makes a difference.
#16
Originally posted by: twentycharacters
Red400EX, good post.
just curious, how often do you change YOUR oil in YOUR TRX450R? what about your racing friend?
I am saving now to go big bore. I will look at the sleeve then, but I bet it will still be in great shape. My engine guy told me, he would take me to 500cc's for $450. I am liking that, and want higher compression, so the 500 is going to be on the way. It might take till spring, but will be worth it.
#18
All this talk about oil change intervals and no mention of oil type. Certainly a synthetic oil like one of the 4Ts would be a welcome addition when doing a 20 - 30 hour stretch between oil changes. This sould also be considered when deciding the oil change interval of your own quad.
I know engine manufacturers stay away from the mention of synthetic oils, does the Honda manual mention anything about synthetics? I'm curious because I will be buying an 06, 450R soon and I don't want any surprises.
#19
Thanx for the feedback guys. I was just wanting to see what you guys have to say compared to the CRF450 owners. I think even the CRF450R's are fairly reliable as long as the oil is changed somewhat frequently and the main thing is to stay off the rev limiter. A lot of the CRF450 horror stories are from a few guys that bounce it off the rev limiter a lot and do not check the valves after such a beating. Most guys are just doing a valve check once a year and their's is running fine.
If anyone else has anything to add please do.
Quadzilla Heritage
09-25-2015 01:39 PM
