Advice on swingarm pivot bolt 250x/300ex
Old Jan 14, 2006 | 01:02 AM
DRUEandTYLERSdad's Avatar
Default Advice on swingarm pivot bolt 250x/300ex
Im trying to remove my swingarm from my 1991 250x. I have everything out now except the swingarm bolt. I have taken all the footbrake assembly off and now all I see on one side is the allen head of the bolt, the other side is threads. I put the nut back on the threaded side, used a piece of wood and a hammer and started to drive it out. So far it has come out about 3/4 of an inch but it seems not to be going easy. Am I dont this right?? Is there an easier way? Any advice would be greatly appreciated.
Thanks,
Corey
Old Jan 17, 2006 | 01:44 AM
Finally got the thing out of there. From the looks of things, nobody had EVER taken it out before. I used a 300ex tie rod and an 8 lb sledge hammer to get it out. Took around 2 hours off and on.
Old Jan 17, 2006 | 07:10 PM
TractorPacker's Avatar
Do you have a balloon?
Good that you got it out. They can need a torch, sometimes. Throw that one away and get anew one. All new bushings at the same time, also. Then smear grease all over it upon re-assembally. It also helps to pull it out once or twice a year and greasing it.
ultangler
Nov 30, 2024 01:35 AM
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
wrencher82
Sep 28, 2015 10:02 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
