06 recon clutch problems!!
Old Feb 6, 2006 | 08:30 PM
cj06recon's Avatar
Default 06 recon clutch problems!!
i have a new 06 recon, manual shift. sometimes i can be in like 4 gear and try to downshift and it wont down shift, other times i can be in like 2 or 3 and i cant shift up or down, it gets stuck in gear and will not go to another gear. i then keep going and keep trying to downshift or upshift and it will all of a sudden act right, anyone now whats wrong?? thanks
Old Feb 6, 2006 | 09:52 PM
1988TRX250R's Avatar
First thing to do is check the clutch adjustment. Its on the front engine cover. Loosen the lock nut, turn the screw counterclockwise until resistance is felt. Then turn the screw clockwise 1/4 turn and tighten the locknut. I'm curious how many miles you think are on the machine. Being an '06 I'm guessing not many. If the clutch adjustment doesn't work, then you may have to pull off the clutch cover to investigate.
Old Feb 6, 2006 | 11:03 PM
SFA's Avatar
SFA
I had a 99 recon that started doing the same thing after I had it for about 7 months. It would miss a gear sometimes too. My warranty ran out so I just rode it the way it was, I tried adjusting the clutch like 1988TRX250R described but to no avail. I never did get it fixed, just sold it.
Old Feb 8, 2006 | 02:40 PM
cj06recon's Avatar
i would say it has less than 100 miles on it, only about 4 tanks of gas ran through it so far, still under warranty, it may have less than 50 miles on it or close to it. only had it since begining of jan 06
Old Feb 8, 2006 | 10:39 PM
recon99's Avatar
It's still under warranty, just take it back to the dealer and let them figure it out. Trying to fix it youself can void the warranty.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
coolguy420
Jul 10, 2015 01:17 AM
