Need help with 06 450r new girl on the block lol
Old Feb 16, 2006 | 09:41 AM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Default Need help with 06 450r new girl on the block lol
Like I said, I have the FMF Q2 pipe and I ride the Oregon dunes too a few times a year. It seems to be quiet enough and really helps the performance.
Old Feb 16, 2006 | 11:12 AM
dunefool's Avatar
Make sure they/you adjust you idle up a little from stock. The idle adjust **** is under your right upper frame rail just above your cylinder. If your shop has a dyno, you might want to have them check your pilot jet and see if it needs to be stepped up to a 45 from stock. The HRC kit for 06 models doesn't adjust the pilot jet up and it may be necessary. When you stall it, do you give it any gas when hitting the starter button?
Old Feb 16, 2006 | 11:18 AM
dunefool's Avatar
Also, this may help some people on their '06's..........
http://www.hmfengineering.com/forums...ead.php?t=1310
mine starts first kick when warm and two or three when totally cold.
Old Feb 24, 2006 | 01:18 AM
CraquE's Avatar
I know I'm a little late in responding and you may not even read this, but in case you do here goes. I have an '06 R. I've got the HRC kit in (which rocks), K&N, no lid (it's removed when the HRC kit is installed), HMF Carbon Fiber pipe and had it jetted and dynoed professionally. The trick I found to starting my bike is this... don't give it any gas when you crank it over. I rode a 400EX for 4 years and you had to give it a little gas to start it every time. If you give the 450R any gas (on mine), it won't start. This was true before I put the HRC kit on. I rode it for 2 months with the HRC kit installed before I put my HMF on. After every mod I did to it, it started everytime with ease if I didn't give it gas. The choke is amazing on this bike. Choke it, let it idle, turn it off and I'm good every time. If I kill it or stall, it may take a crank or two, but if I don't get on the gas I'm good to go shortly. I only give it a little gas once it's turned over and running. I've tested this on 3 other '06 Rs and it worked the same.
Later
ReconBayou
Oct 31, 2022 05:37 PM
MooseHenden
Family ATVing Photos
Oct 5, 2015 08:14 AM
LemonTea
2) Chassis problems..
Oct 2, 2015 03:50 PM
nastyblaster100
Sep 13, 2015 01:19 PM
