HELP/ADVICE ???
Old Nov 11, 2000 | 09:07 PM
hondaflyer400ex's Avatar
If I put a 14 tooth sprocket on my 400ex will it be a noticable differents in bottom end torque ? and how much top end speed will lose ?
honda 400ex
Old Nov 11, 2000 | 09:37 PM
JRM's Avatar
JRM
I have no idea whats stock, but by the way you sound its a 15 tooth, My Experence with Front sprockets is that one tooth is about a half of a gear.. if you go down to a 14 from a 15 its like almost having one more lower gear, but not quite. Top speed will be just above your current 4th gear top speed. On my old XR500R I dropped one tooth on the rear and went up one on the front for dual sport road use. I went from a 80MPH top speed to well over 100MPH
Old Nov 11, 2000 | 11:44 PM
noo !! I do know it does not effect top end by nearly that much maybe 5-8 MPH cause think about it, it's only going to give you about 1 less tire turn for every 20 or 25 (maybe even more) tire turns you would normally get, so there for top end can't be decreased by any more than 5-8 MPH. And atvconnections sport editor told me i'd lose about 5-6 mph at the most !!! and removing one tooth in the front is equal to removing 3 in the rear !!
bobbydcee
1) Engine problems..
Apr 9, 2020 09:53 PM
greek271
Aug 8, 2015 08:16 PM
mark02TJ
May 25, 2014 02:58 PM
birdy
Jun 4, 2013 10:20 AM
G. Manninen
Sep 7, 2011 11:11 AM
