My Honda 400ex won't start, help
Old Mar 27, 2006 | 01:10 PM
dunefool's Avatar
Default My Honda 400ex won't start, help
Yes, but did you also drain the carb down the bottom of the float bowl?
Old Mar 28, 2006 | 07:32 PM
Andy14225's Avatar
well i got it started today!!! got a new spark plug and drained the gas from the carb.Fired right up. Thanxx
Old Mar 28, 2006 | 08:21 PM
TractorPacker's Avatar
Do you have a balloon?
LittleBill owes someone $5.
Old Mar 30, 2006 | 05:43 PM
Andy14225's Avatar
Yea ill be waiting for that 5$ ---accepting paypal ...lol!!@
Old Mar 30, 2006 | 06:44 PM
  #15
BioWare's Avatar
Toxic Ryder
My buddy had the same problem. If you do alot of riding in the winter it will foul the plugs out really fast. They way he fixed the problem was he put a different pilot jet in the carb, and now has no problem with the plugs fouling out.
Just my two cents..
Old Apr 2, 2006 | 07:23 PM
  #16
DEM's Avatar
DEM
Bad gas....
Old Apr 2, 2006 | 10:17 PM
  #17
Remito's Avatar
I gave up and took it to the dealer, apparently when you store the bike, you need to drain the carb and put some fuel stabilizer in the gas tank, otherwise gelatinous goo buils up in the hoses and jets and clogs the carb.
Old Apr 26, 2006 | 09:16 PM
  #18
vd's Avatar
vd
I think the dealer is feeding u a line, 400ex's need to have extra/full battery power to start them if there is something wrong in the power train like
loose exhaust
loose airbox / dirty
loose wiring / plug
incorrect plug
stale gas / blocked tube for tank breather
low battery / loose connections
cold temp outside / wrong choke setting
Check the exhaust and air box for tightness and put a new plug in with a full tank of fresh gas and jumpstart it with a car and adjust choke correctly and i bet it'll fire right up the next time this happens.
always use your back up starting system to help you determine if there is something really wrong, which for the 400ex is getting a good push from a buddy and popping the clutch in first or second gear. Try it next time!
Old Apr 27, 2006 | 02:02 AM
  #19
440EX026's Avatar
That is true or can happen, but its not normal for a short time storage (well maybe the jets could gel up pretty quick if it was poor or old fuel to start with) and more typical of a long term one.
I guess a lot of it depends on luck as well since I know of more than one that had not been used in almost a year that started up fine once the battery was charged up. I also have seen guys dumping $30 or more of stabil into their boats around here, and others that dont even coat the cylinders or add anything and they all have no admitted problems.
Then I had a sportster that got so clogged up the carbs needed rebuilding, and same thing once when the marina missed the stabil, so I guess its easier to just be preparred than gamble.
On the 400 I wont say I never had trouble as not to jinx myself, but I know for sure that if you dont charge up the battery there is a good chance it wont be starting even if there are no other problems. It seems that the starter does not have much room for error as the starting speed isnt much above the min speed, and if the battery is a little weak it can easily cause it not to start.
Old Dec 26, 2018 | 01:10 AM
  #20
My400exsucks's Avatar
Default I’ve tired everything
I was riding down the street and my 4 wheeler just cut off. I said screw it and let it sit for a while before I started to fix it and now it woulnt start but it tries to turn over. I drained the gas out of the carb and tank and put good gas in it, checked the kill switch, saw the spark plug fire, opened up the carb and sprayed the jets with carb cleaner, checked the compression and everything is fine but it woulnt turn over..... any suggestions?
neilbedwell
Nov 10, 2018 11:02 AM
DTroyer01
Jul 3, 2015 07:34 AM
1000gade
May 27, 2015 12:37 PM
lovinhonda
Jan 25, 2000 09:17 PM
roktoy
Aug 25, 1999 04:37 PM
