TRX 300 starting in gear
Originally posted by: JimmyHoffa
Theres a switchamaroo on the clutch that tells your ride wether or not to start. If the clutch is pulled, it goes. If the clutch is let out, it won't start unless it's in neutral.
#16
Donno if it helps, but the ignition switch on my quad seems to eventually run next to about EVERY OTHER STOOPID WIRE in my entire fourwheeler, so my best guess is that you didn't make wiring mistakes, you just jarred something loose during installation. Check 'er over.
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
