recon going trough mud
Old Mar 26, 2006 | 09:49 PM
  #61
hillclimbingrecon's Avatar
Default recon going trough mud
I know did you see that one polaris with like 4 feet of fram clearence. On some of those pits If you want to go through somthing that deep get a boat. Also If you want an opion i would try net zero its fast and relable kinda like a recon lol. I was out riding in my creek today and did not see this sip in the ground and my exhaust went about 2 inches under water man that was scary and cool at the same time
Old Mar 26, 2006 | 10:47 PM
  #62
recon99's Avatar
I'm going to ITT for Computer Electronics Engineering Technology, so I know a few things about computers, and toast.net is superior to netzero in every way. The only way i'll ever switch my ISP is if high speed becomes available in my area.
Old Mar 26, 2006 | 10:59 PM
  #63
oh, from all the info you have given me i thought you might be studing to be a quad mechanic. would dirt bike handle bars fit on arecon because i ordered a pair of handle bars and turns out they are dirt bike handle bars. And if they do fit would i need to remove the center console.I was looking at the clamps and it looks like the clamps would make the console go right over the bars
Old Mar 29, 2006 | 10:10 PM
  #64
hello?
Old Mar 29, 2006 | 10:47 PM
  #65
recon99's Avatar
Sorry, I didn't see your last post. I'll look at the 250ex tomorrow and see how the dash is mounted, but if you bought handlebars with a crossbar you probably won't be able to use the dash. I don't know what to tell you about what to do with the key switch and lights, maybe i'll get an idea after I take a look at how the dash mounts and how much clearance is there.
Old Mar 30, 2006 | 03:57 PM
  #66
Your exhasut for the recon was a mega max 2 right well isnt that a exhasut for a 250ex and did it fit right or did you make any adjustments?
Old Mar 30, 2006 | 05:14 PM
  #67
recon99's Avatar
No, the megamax 2 I had was sold specifically for the recon. If you look at the picture you can see that the hangers aren't welded on, they are just like a loop, so really it could fit either a 250ex or recon perfectly. If you found one for a 250ex that had the same hangers then it would work great, but if it has welded on mounts then it won't bolt up the way it's supposed to.
Old Mar 30, 2006 | 06:26 PM
  #68
oh thats cool. Did you jet the carb or do you HAVE to jet the carb
Old Mar 30, 2006 | 10:20 PM
  #69
recon99's Avatar
I didn't need to jet, it takes a lot to throw off the recon's jetting. I didn't need to rejet until I got the k&n
Old Mar 30, 2006 | 10:30 PM
  #70
so if i put the mega max 2 on i would be able to bolt it on and then just ride with out jetting? Because I want my recon to sound loud but not super loud
