84 trx200 spewing oil from pulse generator
Old May 25, 2006 | 02:20 AM
kingsnake's Avatar
Default 84 trx200 spewing oil from pulse generator
Anyone know why my 84 trx200 is spurting oil out of the pulse generator cover, I opned it up and it looks as if it is designed for overflow but there is a lot of oild coming out of there. Could this just be by desing and there is a bad gasket?
Old May 25, 2006 | 02:05 PM
wadesy's Avatar
There should be a gasket and an O-ring behind the pulse generator body. If there are no cracks in the body this seems like the most likely cause. the Gasket and O-ring are only about 4 bucks each so this would be the logical place to start. good luck
Wadesy
Old May 25, 2006 | 07:42 PM
kingsnake's Avatar
Thanks for your quick reply! The housing cover has what looks like a drain on it, is this designed for the issue I am describing. ie: if the gasket is not in tact the oil is designed to be able to flow out so as not to just sit there in the pulse generator body?
Old May 26, 2006 | 02:03 AM
KNOWSALOT's Avatar
The Facility
Oil should not be in the pulse generator housing at all. It sounds to me that the cam shaft seal is bad.
You will need to remove the outside cover and the timing advancer, and then you can see the seal.
It can be replaced without removing the rear portion of the housing. Just be careful to not scracth the cam or it will wear out the new seal over time.
Old May 26, 2006 | 04:00 PM
kingsnake's Avatar
Which cover are we refering to? The pulse generator cover?
Old May 30, 2006 | 11:36 AM
wadesy's Avatar
Have you taken it apart yet?
Shainasmash
May 8, 2017 06:38 PM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
carid
Sep 14, 2015 03:40 PM
Hondamx751
Aug 13, 2015 01:06 AM
CRamshaw777
Jul 18, 2015 05:46 PM
