NEED HELP! on 400ex i purchased
i got a 2004 trx 400 ex and when i get about into third geer and accelarte it will start to shake back and forth teh fatser you go the worse it is. The 4 wheeler was used for racing before i bought it so it has extended a arms +1 on each side and has works suspension so it sits low and all the bolts and everything are tight ; i was thinking maybe becuase it is so wide in teh front and becuase its probably made for racing but please give me your input i need your help and if you know what my problem is then what can i do to fix it
Neither your a-arms themselves nor the steering stem should be causing what you describe. You could have a bent rim like recon ranger stated. It could be time for new wheel bearings too. I have heard that sometimes if you run tire slime or a similar product, it COULD cause the wheel to be out of balance. That would also account for your problem. In any case, I would fix it before something fails on you. Not pretty if it is a bearing problem when it fails completely[img]i/expressions/face-icon-small-mad.gif[/img]
