what you think? 400ex problem
Old Jul 28, 2006 | 01:06 AM
Daveyboy440's Avatar
Default what you think? 400ex problem
Ok well hes a not soo quick story, I have a 01 400ex bored to 440 typical upgrades (cam, piston, etc.,done by previous owner) driving with a passenger one day and it locks right up and dies and i had to quickly put the clutch in b4 i lost total control. but anyway it wont run now, when i try starting it ,it sound alot like its not turning the crank or moving the piston just a fast whining or spinning noise, i put it in 1st and tried starting it (not push start) to test the starter and it is fine it will propel the thing forward, so what you think b4 i pull it all apart ? Crankshaft, rod, or cam could be broken? let me know if anythin similar ever happened. Thanks
Old Jul 28, 2006 | 03:40 AM
JLsparky7's Avatar
Prolly blew up the piston and crank, only thing i can think of.
Old Jul 28, 2006 | 06:37 AM
HondaMechanic's Avatar
none
Old Jul 28, 2006 | 10:41 AM
thats what i was thinking...awell its only 200 bucks for a new bore kit so hopefully its as easy as that. thanks guys
Old Jul 29, 2006 | 06:22 PM
well the engine came out and all i can find so far is a broke timing chain and some badly chewed guides. where do i go about getting a profab timing chain or should i stick with oem.
Old Jul 30, 2006 | 12:33 AM
quicksilver's Avatar
if you have a broken timing chain check the valves and make sure they aren't bent. If they are bent, might have to get new valves and a valve job done on the head, also make sure the valve guides are ok in the process. good luck.
Old Jul 30, 2006 | 08:30 PM
YamahaRider8998's Avatar
does anyone know if that is common to happen to a 440ex? i was thinkin of gettin one
Old Jul 31, 2006 | 02:00 AM
all i know is my 440 was faster than a 650 even with work done to em.. weird i know but its crazy
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
yambam13
Jul 4, 2015 01:49 PM
