foreman lift kit
Old Aug 16, 2006 | 07:58 PM
JRJW's Avatar
Default foreman lift kit
where can i get a lift kit for av 05 foreman 500 4x4 es that will allow me to fit a 30 inch tire
Old Aug 16, 2006 | 08:55 PM
RancherATCrazy's Avatar
[img]i/expressions/face-icon-small-shocked.gif[/img] [img]i/expressions/face-icon-small-shocked.gif[/img] [img]i/expressions/face-icon-small-shocked.gif[/img] 30 inch tire???? Do you plan on rolling down all the hills? On a 500 I wouldn't go any bigger than a 27" and that is pushin' it. But if you really want to for whatever reason and you want to do it right you will have to fab somthin' most lift kits you can buy only raise you 2 inches. If you are running 24" tires now which I think is stock on the 500 you will need a 2 inch lift to go to 27" tires. If you want to roll 30 " tires and still have any kind of fender clearance you will propably have to lift it yourself. I have never seen a pre disigned lift over 2 inches.
Old Aug 16, 2006 | 08:59 PM
JRJW's Avatar
nv lifted an atv so i guess 30s are big my stockers are 25s if i get a 2in its going to be a highlifter what size tire that allow me to fit without rubbing
Old Aug 16, 2006 | 09:10 PM
You seem to be stuck on big tires so I would go for a 2 inch lift and some 27" tires but you will loss power and tip easier on the trails if it were me I wouldn’t lift it at all and just throw some good 26" tires on. What kind of terrain do you mostly ride?
Old Aug 16, 2006 | 09:27 PM
JRJW's Avatar
what im worryed about is rubing on the finders will 26s rub any. i mostly trail ride, some mud, and some on road traveling to get to the trail head from friends houses. i was thinking ITP MudLites on ITP Type-6s
Old Aug 17, 2006 | 01:44 AM
If you are running 25" now you could bump up to 26" without a lift and without any rubbin' If you mainly trail ride and if you are going to run on any hard pack I would recommend the mudlite XTR's over the mudlite's the lugs are closer together making it much better for trail and hard pack, it won't wear as fast it's a smoother ride and you will still be able to sling some serious mud. That is what I am getting once I find the $$$. If you go up to 27" I would recommend a lift. But for what your doing I would stick with 26ers [img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 17, 2006 | 11:08 AM
JRJW's Avatar
thanks for the help
Old Aug 17, 2006 | 08:41 PM
No problem, and welcome to the forums! [img]i/expressions/face-icon-small-wink.gif[/img]
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
QuadRiders
Oct 22, 2015 04:13 PM
mark23
Oct 1, 2015 09:57 AM
patrick.oc123
Sep 15, 2015 02:45 PM
