400ex sprocket change not wut i wanted
"In my area, almost everyone drops a tooth on the front as soon as they get their quad. We have lots of hills and very tight woods and top speed is not a worry. How often do you really ride wide open in high gear for any period of time?"
When I first dropped a tooth on my 400ex, I regretted it. However, I now love it. I only lost a bit of speed and the engine revs higher now when it's pinned in 5th, but it doens't lose power when I get to steep hills and what not. The benefits of the lower gearing on bottom end outweigh the negative factors of lower gearing on top end. I can lift the front end up in 5th and I can wheelie much easier. I can drive really slow without even touching the clutch. If I think the bike is abot to stall, all I have to do is give it some gas and it'll rev back up again (don't even have to touch the clutch).
I can imagine that the 400ex is probably an incredibly fun machine with even lower gearing (say maybe a 14/39 or 40 combo). I don't think going down to a 13 tooth will add to enjoyment though.
Originally posted by: mjm540ii
jed do you slip the clutch when you pull it up in 5th? (jw)
Lifting it up in 5th is definately possible with a stock 400ex. I've seen my friend do it. It's much tougher to do though. Most of the time though. Although it's great doing wheelies in 5th, it is more thrilling to be able to shift while you're doing wheelies. I can get it right up to 5th and I don't even consider myself a pro yet.
i lowered my front sproket on my 01 400ex and wanted just a little more revso i added Magnum rev-box and boy did that help. i actually ended up gaining about 2-3 mph more top end and it lets me hill shoot much faster. it only costed me $50 and i consider it a great invesment.
#15
