Stupid question about checking oil in a Rubicon
Old Oct 7, 2006 | 06:22 PM
swingset's Avatar
Default Stupid question about checking oil in a Rubicon
Ok, easy enough.
According to the manual, you let it idle, warm up, shut it off and let it cool a bit before checking. Gotcha.
You unscrew and remove the dipstick, wipe it off, reinsert it but DON'T screw it in, and rely on that reading to check oil level, yes?
Ok, now, here's what's stumping me.
Where on the dipstick do you insert it to? The dipstick has a plastic shaft near the threads, and the end meets resistance as it goes into the check hole. Do you insert the dipstick all the way TO the threads, but not screw it in? Or, do you insert it to the begining of the plastic shaft? Look at this diagram, for reference.
http://www.localnumber69.com/temp/dipstick.jpg
Here's the problem. After my oil change (the first I've done myself since the shop gave me the first 2 for free), I filled to just below factory capacity (5.2 quarts). I think I filled to 5 quarts. If I check the oil by putting the dipstick in TO the threads (red arrow), it reads waaay high. If I put it in to the beginning of the shaft thingie (blue arrow), it reads just below max on the dipstick (perfect). Which is correct? The manual is vague on this.
TIA.
Old Oct 8, 2006 | 09:54 PM
d33pt's Avatar
put it in to the threads..when it seats.
Old Oct 9, 2006 | 12:07 AM
swingset's Avatar
Gotcha....my local Honda dealership told me the same thing today. Weird thing is, this makes the capacity of my Rubi about 4quarts, nowhere near the 5.2 that the manual states in order to get a proper oil reading.
Old Oct 9, 2006 | 01:42 AM
HR's Avatar
HR
i think y9ou didn't let it drain long enough. doesn't it have 2 oil coolers? did you give them time to empty?? my rancher qt was off too. took like 4.2 where they told me 5 Q and you did change the filter didn't you..?
HR
Old Oct 9, 2006 | 05:21 AM
swingset's Avatar
I definately let it drain thoroughly.....like 2 hours draining, it wasn't dripping at all and I followed the manual exactly...and yes I changed the filter as well. Weird, unless there's a resevoir somewhere that doesn't drain off, I dunno how the capacity listed is even remotely correct.
KimSJoh
14
Jul 18, 2015 07:20 PM
toonces
Jul 11, 2015 12:01 PM
200es
Jul 10, 2015 09:09 AM
sara durrant
Jul 6, 2015 05:32 PM
D-Hagz
Jul 4, 2015 02:19 AM
