02' Honda TRX450FM Cylinder bore ? HELP
Would anyone be so kind as to give me the inside bore dia. of the cylinder ? This atv ran out of oil and scored the cylinder and ruined the piston . This atv is used and I do not know the history , so I need to know if I can bore it out .
So, I need to know the standard bore of the cylinder.
Thanks So Much,
D.
Thanks So Much,
D.
Out of curiousity, I priced a new cylinder, piston, rings and gasket set from Babbits... You're looking at about $350 if you wanted to do the work yourself with factory new parts. Sorry, I don't have the spec for the bore:
http://www.oem-hondaparts.com/
Stirling
08-09-2015 01:49 PM
TLC
07-11-2015 02:28 AM
