????400EX 2005 Stock Rear Wheel Size????
jrafter-What you gave him is the stock TIRE size........
If you have a rim you can look at, the size is stamped on the rim..........they are 9X8 (can't remember the offset???), which means the rim diameter is 9", and it is 8" wide.
Do you need to replace some rims???? First thing I do when I get a new quad, is ditch the stock rims! I replace them with ITP rims that are 9X9 and have a 3+6 offset. That combined with some wider tires, leaves me +3" wider for a real nice increase in stability.
