Honda Recon 250EX not starting suddenly
Old Dec 24, 2006 | 04:05 PM
BaileyBaileyBeckwick's Avatar
Default Honda Recon 250EX not starting suddenly
06 Honda recon 250 EX vy low hours just around the yard and into the woods.
Started it up yesterday with the choke closed. Ran then stalled. Opened the choke a little and restarted. Ran then stalled. Started and stalled.
Then it wouldn't run at all. Just crank.
If I close the choke, It'll backfire after cranking a lot.
Pulled the plug and cleaned.
Held the plug against engine and got spark.
Pulled off fuel line and confirmed flow.
I don't know a lot about these. Is there any other things I should check before I have to take this down somewhere?
Thanks.
Old Dec 24, 2006 | 04:56 PM
Scooter86's Avatar
Knows Old ATV Questions!
There are a lot of little things that COULD be causing your starting woes. Is your air filter clean? Check the breather vent on the gas cap for any blockage. Still won't start, throw on a new plug. If that doesn't work, then drain the gas and add fresh. Putting a little gas or starting fluid down the pug hole may help. If it fores and runs for a few seconds after that, then you pretty much have it narrowed down to a carb problem at this point. A few things to check in that case would be make sure the jets are clean and open and the floats are at the proper level and not stuck. Good luck and keep us updated on your progress.
Old Dec 26, 2006 | 12:40 AM
jrafter's Avatar
get a new plug
Old Dec 29, 2006 | 10:49 PM
Picked up a new plug and it started right up.
Is this a common problem/fix?
Thanks for the help!
Old Dec 29, 2006 | 11:47 PM
Scooter86's Avatar
Yup, new plug is a good place to start usually. What did your old plug look like when you pulled it out? It is possible your quad is running rich for some reason.
Old Dec 30, 2006 | 09:41 PM
jrafter's Avatar
Im kinda wondering this myself......i seem to be changing the plug about every 10 or 15 hours......it might be over kill
just seem to run better if i keep it do.
Old Dec 30, 2006 | 10:04 PM
Scooter86's Avatar
jrafter, that is way to often to be replacing a plug. There is something out of whack with your quad I would think. Could be you are using the wrong plug, the plug isn't gapped properly, there is an insufficiency in the electrical system, or your carb needs a little tweaking.
Old Dec 31, 2006 | 12:52 AM
bombrider04's Avatar
Yea if you are fouling plugs like that then there is def a problem like scooter mentioned I would start with checking to see if there is a direct short, what scooter said or jetting si off
Jun 10, 2015 12:45 AM
'86 TRX125
Jun 6, 2015 07:43 PM
KingKodiak4x4
Jul 9, 2000 12:59 AM
ATV4ME
Jun 28, 2000 12:45 AM
bgarre
Jan 23, 2000 10:17 PM
