2005 HONDA Rubicon WINCH
Old Jan 6, 2007 | 11:17 PM
tams07's Avatar
Default 2005 HONDA Rubicon WINCH
DOES ANYONE KNOW IF IT IS PRE WIRED FOR A WINCH IF SO WERE
Old Jan 7, 2007 | 12:58 AM
JRM's Avatar
JRM
not pre wired, sorry
Old Jan 7, 2007 | 01:47 AM
tams07's Avatar
DO YOU WHAT THE WIRE COLORS ARE I NEED TO TIE IN TOO AND WERE THAY ARE
Old Jan 7, 2007 | 09:30 PM
dhopfinsd's Avatar
Just completed wiring my Honda Rancher 400 this afternoon. The hardest part was finding the ignition hot wire for the winch control switch.
What brand winch did you buy?
Don Hopf
Old Jan 7, 2007 | 09:59 PM
tams07's Avatar
i am going to try the vendom brand i have too warn and i do not think thay are all that good and thay cost a lot so i will try this one it was like 130.00 for everything so i will give it a shot it look just like a warn.
Old Jan 7, 2007 | 11:46 PM
ForemanDan's Avatar
Are you saying you already have a Warn? A Venom is a copy made in China.
Old Jan 8, 2007 | 11:25 AM
dhopfinsd's Avatar
I got a Viper 2000 LB from an Ebay store for $118. That include shipping, mounting bracket, fairlead, winch, remote electronic box, and a handlebar mounted thumb switch.
Had the bracket and winch per the instructions in the machine in less 90 mins.
The wiring harness was another story. The instruction were just how to wire the winch, electronic contactor box and thumb switch. No particular make or model of any ATV was illustrated. Was pretty much on my own on how to run the wiring harness.
Old Jan 8, 2007 | 10:19 PM
csr44's Avatar
I put the Venom on my 05 Rubicon and it has worked great so far; on my second season plowing. You can use the "pink" wire that comes from the key switch for the power source. Carefully make a cut in the harness wrap with your utility knife by pulling some slack at the top with your fingers, making sure not to cut into the wires inside, then just pull up some of the pink wire, attach the splice connector, plenty of black tape and your good to go. I mounted the solenoid on the right side of the rear storage box and the supplied power and ground were just a bit short so I extended them with the same gage wire.
If you have any other questions, I can walk you through it.
CSR44
Old Jan 8, 2007 | 10:30 PM
tams07's Avatar
thanks i will be puting it on this week end if i have any question i will ask
toonces
Oct 19, 2015 02:21 AM
MNatv89
Aug 10, 2015 02:20 PM
Bratman2
Jul 23, 2015 12:36 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
