THIS CHAIN IS DRIVING ME CRAZY
Old Jan 23, 2007 | 11:45 PM
imadimetooo's Avatar
Default THIS CHAIN IS DRIVING ME CRAZY
ok I have a 1994 ex 300 and I can not get the cain tight it has the 2 12mm bolts but thats it I wen't to the stealer and they could not even pull up a pic of the swing arm also there is a hole in the arm that looks like some type of oil goes there and if so what type thanks guy for your help also I don't know if that is there right arm for the bike
Old Jan 23, 2007 | 11:58 PM
QWODER's Avatar
There is a picture on bikebandits.com.If that hole is on the very end of the swingarm,I think that is where a bolt goes that is a stop to keep you from spinning the bearing carrier past its tightest point.If your chain has been stretched to its farthest tightening point then you may have to take a link out of your chain.Hope I havent confused you.
Old Jan 24, 2007 | 01:11 AM
ok but on the chain on newer models there is a chain adjs and on this one there is not so when I go buy a new chain how will I tighting it then thanks
Old Jan 24, 2007 | 09:55 AM
QWODER's Avatar
There has got to be some adjustment.On 300ex,the whole bearing carrier that the axle goes through will rotate.The carrier is kinda egg shaped and when you turn it,it should loosen or tighten your chain
Old Jan 24, 2007 | 01:47 PM
bombrider04's Avatar
exactly qwoder...If the chain is tightened all the way and is still loose then the chain is strectched and is most likely worn...you could take links out but I would get a new chain along with new sprockets because when one is worn you change the others.
Old Jan 25, 2007 | 12:47 AM
QWODER's Avatar
bombrider04 I dont think he has figured out how the tightening system works on this atv yet.imadimetooo have you had any luck yet?
Cummins Driver
Sep 11, 2019 01:22 PM
U2OFlyer
Aug 5, 2015 12:46 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
95wolv
Jul 17, 2015 08:13 PM
joeyupton
Jul 14, 2015 11:51 AM
