wheel alignment
Old Feb 9, 2007 | 06:44 PM
bombrider04's Avatar
Default wheel alignment
http://noleenshockservice.com they have a tool that will measure for front end alighnments or you could do it using the way mentioned before...I have a question for you guys also, how do you balance atv tires? I know you need a machine to do so but do you use weights like on a car? any info would be helpful
Old Feb 9, 2007 | 06:57 PM
JamieBing's Avatar
I worked in a tire and repair shop for many years. We used and old fashioned bubble balancer and used stick on wheel weights placed on the inside. Usually the problem was the tire was not properly seated on the wheel rather then out of balance. You may consider breaking down the tire and lubricating it well and reseating the tire on the wheel. I usually would take a rubber mallet with the tire assembly laying on its side and give it a "wop" as I worked my way around. A similar process we used to get a better runout on large mud tires for 4wheel drives.
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
