88 300 fourtrax 4x4
Old Mar 3, 2007 | 11:32 AM
scottddove's Avatar
Default 88 300 fourtrax 4x4
I want to try to get the push button starter to work again on this machine. here is a history on what is going on with it. replaced the battery with no affect. I have a car starter/battery charger I can put on the battery posts and it will start up. I suspect the solenoid but don't want to just throw parts at it. Can anyone tell me where to start to try and fix this.
Old Mar 3, 2007 | 10:49 PM
Madwolverine's Avatar
Inspect the cable connections at the battery closely; I'm thinking you may have a bad connection. (I would clean them just to be sure) By jumping it off you would be providing a "good" connection directly to the cable ends.
If that's not it let us know.
Old Mar 9, 2007 | 10:02 PM
scottddove's Avatar
ok I did find one problem a blown fuse that caused the green neautral light and the red reverse and oil light to come on. I cleaned all the connections and still no start with the push button from the battery. I still can put the booster on and it will start right up. I was thinking it might be the battery itself. I can hear the cylenoid click if I put my ear right at it. any ideas???
Old Mar 10, 2007 | 10:02 AM
Did you cleaned and tightened the cables? I always look for the easiest problems first. It may very well be that you have a solenoid problem. Sometimes extra juice from a jump will mask such a problem.
Old Mar 10, 2007 | 02:54 PM
scottddove's Avatar
yes I took off all the main connections that go to the battery, solenoid, and starter and cleaned them and tightened them back down. I did find the blown fuse like I said but I don't think that is it. So if you put extra juice on the battery it will make the solenoid work??? how can I check the solenoid or is it just a part swap thing .thanks for the reply so far.
Old Mar 10, 2007 | 08:36 PM
scottddove's Avatar
got it fixed it was a weak battery and bad connection. thanks for the help
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
wendal
Sep 15, 2015 01:50 PM
Steeldon
Sep 8, 2015 10:51 AM
ScopeZ_
Jul 28, 2015 01:44 AM
