Problems with 85 TRX 125
Old Jun 2, 2007 | 02:43 PM
Billy177's Avatar
Default Problems with 85 TRX 125
I dont think the screen has ever been checked, and prior to this the quad sat outside for almost a year unused, I will check the screen out today and see what I can find.
Old Mar 11, 2018 | 10:17 PM
Justin mathis's Avatar
Originally Posted by TommyA300
<div class="FTQUOTE"><begin quote>Originally posted by: Billy177
well the rattling turned out just to be a loose bolt on the frame however as far as the popping out of gear is concerned it seems that it may not be the clutch after all as it is much worse when going down hill then any other time. at low rpms its fine just when the rpms are high is when it pops in and out</end quote></div>
POPPING ..IN & OUT of gear?
I have experienced a machine popping out of gear but not back in gear.
What gear are you in when this happens and how high of an RPM are you relating this to?
Is the machine screaming like it was ready to blow?
Or is it the Hi RPM just before shifting in the normal power range?
If it was just popping out of gear and doing it in just a particular gear like 1st or 2nd gear, I would suspect one of two things that the shifter is not getting the gears fully engaged after shifting, due to the shifting plate retaining bolt loosened up which is on the face of the shifting drum or the dogs are warn on the face of those gears.
Now you mentioned IN & OUT of Gear which leads me to the clutch, which will feel like it is not pulling or holding back as you are accelerating up hill or decelerating down hill respectivly speaking.
Detail your description please so someone can refine a solution.
I need some help with this 1985 Honda 125m with the transaction is slipping what can I do to fix it can some one call or text me if you have any ideas 989 701 4410
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
