Help with 85 TRX125 carb adjustments
Old Nov 21, 2007 | 07:44 PM
fooey's Avatar
Default Help with 85 TRX125 carb adjustments
Help with 85 TRX125 carb adjustments....
Hello, newbie here, looking for some help with the factory settings for the idle and a/f set screws....
First off, can someone tell me which one is which, then how many turns out each one should be set at according to factory specs...yes I am sure I will have to do some tinkering....
I am about to pull what hair I have left out of my cranium...this thing is driving me batty....I can get it to run, but it does not want to stay running at idle...prolly just needs a good cleaning...
Thanks for any help anyone can provide!
Old Nov 21, 2007 | 09:05 PM
HondaMechanic's Avatar
Old Nov 21, 2007 | 10:00 PM
fooey's Avatar
Thanks a bunch!
so which set screw is the mixture and which is the idle?
I am guessing the one that is in the air tube to be the idle and the one that is almost in the center of the carb body/slide area is the mixture.....correct or backwards?
Thanks again!
Old Nov 22, 2007 | 12:15 AM
hondabuster's Avatar
Backwards. Youll see when you pull out the slide, how the idle screw works. Its just a tip of that screw on a ramp on the slide, which mechanicly opens the slide. If it wont idle, and the idle screw holds the slide open, then you most likely have a plugged idle jet. Just buy a new one, becasue the hole in that jet is so tiny, its about impossible to open it back up. They are like 5 bucks at the dealer.
Old Nov 22, 2007 | 12:26 AM
fooey's Avatar
DOH!
Been a while since I tinkered with a carb...had I thunk about it a bit, I would have remembered what you just stated....I must have lost that brain cell on a 6er a while back....
Thanks for reminding me about the setscrews.....
Old Nov 23, 2007 | 04:32 PM
aratvguy's Avatar
Important note on the mixture screw. When adjusting the screw and it "bottoms out" DON'T force it past where you feel resistance. The screw has a point on the end that is very easily bent if screwed in and forced. If you bend it it won't work right again. Just a note. Hope this helps. aratvguy.
Old Nov 26, 2007 | 01:16 AM
fooey's Avatar
got it working, then it got cold..have to choke it till it warms up....this is what it helped me get:
Now if I could just get a pdf copy of the service manual, I can figure out how to replace that steering bushing and fix the tranny on the other one I have....(hint hint)
Old Jan 1, 2008 | 01:02 PM
fooey's Avatar
update, got it tuned perfectly I guess, never have to use the choke, even though it has gotten cold around these parts...yes, 50 is cold...anyway, I am amazed, I can go out there, turn the power switch on, hit the starter button and it will fire up and run on it's own first time, every time..... [img]i/expressions/face-icon-small-happy.gif[/img]
still have to replace that darn steering bushing.....then I am going to make front and rear cargo carriers....might have a line on the tranny parts I need for this beasts twin that I have in the garage....
Old Sep 16, 2010 | 08:26 PM
fordism's Avatar
Default Total Newby
Is there anywhere I might be able to find an exploded view of the carb on a 85 Honda TRX125? I have this atv and it runs, but it doesn't idle well and when its at full throttle it seems to sputter. I can see dark smoke from the exhaust when it is trying to idle.
Cole Hadden
Jun 15, 2025 09:05 AM
Firefighter400
Oct 8, 2022 06:38 PM
GregM
Mar 6, 2018 06:53 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
