Need Ground clearance
Old Nov 25, 2007 | 09:26 PM
Mainerocker's Avatar
Default Need Ground clearance
Would Like to increase ground clearance on my 2001 Ruby.
I think larger diameter tires is the only way to do it.
How big a tire can I put on safely .
How big without lift kit and how big with lift kit.
If I get bigger tires will I have to change the rims.
Old Nov 28, 2007 | 07:59 PM
njfishnmann's Avatar
without a lift kit I wouldn't go any bigger than 26's. if you get a lift kit you can go to 27's. I have a 2in lift kit with 26in mudlites on my rubicon and have plenty of clearance. stock is 25in but you can put a bigger tire on without changing rims. make sure to only go taller and keep the width and rim size the same. hope this helps.
Old Nov 29, 2007 | 04:48 PM
08Renegade500's Avatar
Friend of mine has 30'' tires on a rincon with a 2'' or 3'' lift. Mud beast, but robbed alot of top end speed.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
salixair
Nov 3, 2015 08:25 AM
Sw00p
Sep 24, 2015 02:50 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
