my 400 AT wont downshift
Old Dec 14, 2007 | 07:21 AM
saby5757's Avatar
Default my 400 AT wont downshift
hey slough... i have been having problems with my bike... and I wasnt sure if it was possibly the centrifugal clutch... how did you know that your was goin bad? what problems were you having? and did replacing it fix the problem?
Old Dec 15, 2007 | 12:50 AM
Gimpster's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: slough
hey gregg i had my centrifugal clutch rplaced by my dealer should i performe the initial setup or does the dealship do that</end quote></div>
Yes, reset the system as I outlined above to make sure it operates correctly
----- Gimp -----
Old Dec 15, 2007 | 12:53 AM
Gimpster's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: mxman76
thanks again gimp. i just have one more question, if my centrifical clutch is bad should i get it fixed first or go ahead and try this setup? and also is it ok to use my quad to push snow in electric mode?</end quote></div>
Sorry that I missed reading this post.
If you use it, make sure that the engine does not get too hot from the clutch slipping. If your centrifical clutch drum is warped, the clutch shoes/weights may not get hot and it can be ok
----- Gimp -----
Old May 4, 2008 | 01:49 AM
cody_lyons78's Avatar
you probably have water or a short in the angle sensor i have one in the shop right now for the same problem if it is still under warranty it should cover it
07' Honda Foreman ES
Maxxis Bighorns on ITP SS108s
warn xt30 with synthetic cable
Old Sep 22, 2008 | 07:41 PM
  #15
Cummins123's Avatar
Default my 400 AT wont downshift"></title><script src=
Gimpster, Help. I went through this sequence and when I was returning to 1st gear it would only return to 4th gear.
Old Jan 29, 2011 | 03:43 PM
  #16
RAMMAD's Avatar
Default my 400 AT wont downshift properly
Hello i am new to this forum and I have a 2006 Honda Rancher FGA that wont shift properly in automatic. I have followed through the steps posted by Gimpster regarding the downshift problem and cant get any codes to come up at the beginning and the display will not flash "--". It stays in 'N'. i tried turning it off and starting over several times with no luck. Could someone tell me why it wont show the "--" please. am i doing something wrong? thx
Clint Russell
Sep 25, 2015 03:20 PM
Madshad
ATC 3-Wheelers
Jun 28, 2015 02:43 PM
madweazl
Jul 18, 2001 10:10 AM
patrailrider
Feb 6, 2001 07:24 PM
1rancher
Nov 2, 2000 11:12 PM
