1987 Trx250x
Old Jan 22, 2008 | 12:56 PM
Thompson creations's Avatar
Default 1987 Trx250x
Does any one know where i can get pro x piston rings? I'm rebuilding the top end on my machine and its got a pro x piston in it . when i went to there site it said that the their rings can be used as stock replacement so i was wondering if i could put stock honda rings into it? my piston is 74mm which im pretty sure is stock. any help would be apreciated.
Old Jan 22, 2008 | 05:56 PM
DX's Avatar
DX
You can buy rings and pistons from rockymountainatvmc.com or denniskirk.com. You can use different rings than pro-x you know.
Old Jan 22, 2008 | 06:12 PM
someone else told me that i had to be brand specific. so your saying that any brand rings will work?
Old Jan 22, 2008 | 06:59 PM
STANG302's Avatar
Not exactly. Some after market companies design there pistons to use there own rings. By making the rings thicker/thiner. I would go with a matching set of rings from pro-x. I am surprised that the piston came with out the rings and wrist pin needed.
Old Jan 26, 2008 | 10:54 PM
when i opened up the top end thats the piston that was in there. i bought the machine used. i read on the pro-x site that their rings will work on a stock piston so i was wondering if i can use stock honda rings
Old Jan 27, 2008 | 01:20 AM
DX's Avatar
DX
<div class="FTQUOTE"><begin quote>Originally posted by: Thompson creations
when i opened up the top end thats the piston that was in there. i bought the machine used. i read on the pro-x site that their rings will work on a stock piston so i was wondering if i can use stock honda rings</end quote></div>
Stock rings would probably work just fine.
Pehter
Oct 3, 2024 11:00 PM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
Steeldon
Sep 8, 2015 10:51 AM
yhp567
Sep 5, 2015 03:29 AM
