need help qiuck
Old Feb 8, 2008 | 04:07 PM
125dillmatt's Avatar
Default need help qiuck
i have a honda atc 200m 1982 and its spitting gas out of the carb when i pull the pull cord could this be one of the valves stuck open in the head the carb is in good condition so is the engine but when i pull the pull chord it dosent go in the carb it shoots into the airfilter need help
Old Feb 8, 2008 | 04:23 PM
dillon
Old Feb 8, 2008 | 06:26 PM
dillon
Old Feb 8, 2008 | 08:06 PM
dillon
Old Feb 8, 2008 | 08:21 PM
Old Feb 10, 2008 | 12:25 PM
J3ffr0's Avatar
check your vacuume lines...make shure pitcock valve hose ish running to lead on carb and not a AIR vacuume line....
Carb ish DRY? try turning gas on and loosen the bowl valve on the carb ..does gas come out? (flathead screw on side of bottom carb)
Old Feb 10, 2008 | 09:24 PM
i think i found the problem i took the head completely off the the piston the timing was way of by 5 to 10 teeth but i fixed it and put it all back to gether and i took the whole engine out so im going to have to put it all back but the weird thing is i was riding for about an hour and parked it for about 20 min. and went bake out never having a problem with it before it wouldnt crank the carb is clean tho i think it was just the timing idk ill now by monday when i put it together im thinking the sproket thats connected to the shaft is warn down in side the head the lower one.....thanks for replieing your the only one on this topic
Old Feb 10, 2008 | 09:58 PM
J3ffr0's Avatar
no prob.. if timing was that far off you prob. need a timing chain...sprokets rarely go out...depending on how long this been happenin..
Hillbilly Deluxe
May 1, 2009 07:49 PM
Big D
Nov 12, 2008 04:20 PM
splescort
ATC 3-Wheelers
Aug 17, 2008 07:25 PM
Tbone9
Mar 21, 2007 10:09 PM
