How to snookle my 2005 350 rancher foot shifter
Old Feb 26, 2008 | 01:12 AM
jasonb_32420's Avatar
Default How to snookle my 2005 350 rancher foot shifter
Yes, i have a 2005 350 rancher 2 wheel drive with 26"super swamper vampires on the rear, and put a 2 inch lift on so i have the ground clearence and i am going more places then MOST 4x4 atv's. Just would like a snookle for the really deep water. I have had it up to my gas tank. and has not shut off yet, but i do not want to take the chance. And i already know how to make my snookle but, what all hoses like vent hoses do i need to move up on the snookle so it won't shut off? thank you for your time.Please let me know...
Old Feb 27, 2008 | 02:23 PM
Is there anybody that knows what im talking about.. With the cent hoses?????????
Old Feb 27, 2008 | 09:40 PM
SwampRancher's Avatar
well jus make sure your not shy on the glue for the snorkle, then look under your seat and u will see 2 small black vent lines that come up and jus stop near the gas tank, those should be your front and rear differential vent lines, jus put a T fitting on those and combine them into one hose, make sure the hose is a lil bigger to carry the load of both vents ( I say get the T fitting and combine the 2 vent hoses together in one bigger hose so this way u have less hoses to run up to the snorkle), then look at your carb. there should be like 2 small vents then one big one, ( i have a rancher 400 but the carb should be about the same), do the same thing combine the 2 small hoses with a T then run that hose up, then get a fitting for the bigger hose and jus run that same hose up, i think i used 3/8 on mine but it doesnt have to be that big, then jus run the vent lines up with that length and height of the snorkel and zip tie them onto the pipe of the snorkle, its really simple to do bud....
Old Feb 29, 2008 | 03:47 AM
well. i already looked under the seat and the only hoses that i see coming from the carb, is the two small hoses and one bigger hose that run from the carb up toward the gas tank... what other hoses you talking about... thank you..
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Johnny Mac
Aug 15, 2019 03:13 PM
salixair
Nov 3, 2015 08:25 AM
Clint Russell
Sep 25, 2015 03:20 PM
rgjackson
Sep 17, 2015 11:21 AM
