portable electric winch
I get how the cable end hook to the stuck object but were do you fasten the other end with a short chain or cable to? Not to the handle right?
<div class="FTQUOTE"><begin quote>Originally posted by: TLC
I get how the cable end hook to the stuck object but were do you fasten the other end with a short chain or cable to? Not to the handle right?</end quote></div>
Negative, comes with removable base that can be attached to a ball mount or you can bolt the bottom to a flat surface
