250R front sprocket spacer?
Old Jan 17, 2001 | 12:59 AM
Adams44's Avatar
on the front sprocket, the sprocket moves in and out about 1/4". Is there a spacer that goes in behind the sprocket??
Thanks
Nick
Old Jan 17, 2001 | 03:01 AM
trapperb1's Avatar
Is the sprocket sliding on the shaft? Or is the shaft sliding in/out? The second would be serious.
The first, nope, there isn't a spacer. Just a big washer on the outside where you put the bolt.
Old Jan 17, 2001 | 12:28 PM
tprender's Avatar
250r sprokets should be flush with the end of the shaft. Some sprokets will have the spacer made on the sproket and some will come with an extra spacer. It will look like a large washer. If your sproket is flat on both sides you must use the washer or spacer. If your new sproket is flat on one side only, the spacer is built into the sproket. If the sproket that you are putting on sets out pass the end of the shaft you need to remove the spacer on the shaft from the old sproket. When you tighten down the bold it should set flat on the end of the shaft with the sproket.
Bratman2
Aug 6, 2022 01:42 AM
Dustinyoungs
Jul 24, 2015 07:18 AM
CRamshaw777
Jul 18, 2015 05:46 PM
95wolv
Jul 17, 2015 08:13 PM
joeyupton
Jul 14, 2015 11:51 AM
