Hard to shift gears
Old May 14, 2008 | 09:41 PM
rhonda350's Avatar
Default Hard to shift gears
I have a 06 Rancher 350 2x4 and it is hard to shift you really have to pull up hard to shift. Its hard to shift in 1st to 2nd and 2nd to 3rd but its not that hard to shift from 3rd to 4th and 4th to 5th. does the oil have anything to do with the shifting.
How do i make it ezer to shift on this bike. I was told to ajust the clutch how do i do that.
Old May 15, 2008 | 12:15 AM
JeffinTD's Avatar
If the clutch adjustment is similar to the Foreman, there is a screw with a lock nut, if I recall correctly on the front of the case toward the left.
You back off the lock nut, then turn the screw in until it bottoms, then back it off 1/4 turn and snug the lock nut.
Oil can have some effect on shifting, as both the clutches and the transmission run in engine oil. Most Honda utilities call for oil with API rating SG or higher, and JASO MA rating- which indicates that the oil provides the right amount of friction for wet clutch applications. 10W-40 would be appropriate in most temps.
Firefighter400
Oct 8, 2022 06:38 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
heath legg
Jul 24, 2015 01:01 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
sara durrant
Jul 6, 2015 05:32 PM
