400ex spark plug stripped....darn
Old May 20, 2008 | 04:38 PM
P-man's Avatar
Default 400ex spark plug stripped....darn
So, it sounds like I should take the head off in any case. Does anyone know a good way to go about it who could point me in the right direction?
Old May 20, 2008 | 05:56 PM
bombrider04's Avatar
The head isn't bad to take off as long as you know the procedure to take and the specs. The best thing to do would be either pm HONDAMECHANIC and see if he can send you a service manual for the procedure or to go and buy one or see if the local dealership can print you some pages for the procedure.
Old May 1, 2009 | 02:29 AM
jinshiyang's Avatar
Usually you can put oil on the tap to chase the thread and hopefully gather all of the shavings, but like I said it isn't really recommended. Check to see if you can find a heli coil to match the threads and put it. Welcome to the forums. Also never use a regular socket when removing a spark plug due to the fact that you can crack the ceramic on the plug.
Old May 24, 2009 | 12:05 AM
jinshiyang's Avatar
I am trying to get certified in as many things as possible that way I am more agile. It is alot of work, but I see around the dealership and no one wants to work on the diesels and thread inserthelicoil
Old May 24, 2009 | 09:23 AM
  #15
JeffinTD's Avatar
It is indeed tough to find a good diesel mechanic.
If you have the chance, maybe you could also get certified in Cummins. If you could snag a job with them, I understand they are a really good outfit to work for.
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
