05 fourtrax runs won't move
Old May 31, 2008 | 07:20 PM
tnabb's Avatar
Default 05 fourtrax runs won't move
[img]i/expressions/face-icon-small-confused.gif[/img] have code 5 flashing on my atv, I have replaced the angle sensor reset the ecm that did't fix my problem. did all the steps in the book leads me to a faulty ecm replaced it reset the ecm again still not working. pulled the wireing harness out of it checked all the wires everything looks good. I am very confused know.
Any help woul be great
Thanks Troy
Old Jun 1, 2008 | 05:07 PM
fmf 400ex's Avatar
what model is it?
Old Jun 1, 2008 | 07:56 PM
wilber15's Avatar
I checked my 07' 500 manual, and it says a code 5 is the ECM driver for the motor? Could be a bad shift motor?
Old Jun 2, 2008 | 10:30 AM
tnabb's Avatar
It is a 400fa gpscape. it has auto and esp
Old Jun 2, 2008 | 10:34 AM
tnabb's Avatar
I tested the motor in one direction only. Should it turn in both directions? I have followed the steps in the manual I have it is for a 500 and it tells me to replace the ecm so I did and the only thing that did for me was lighten my wallet buy $400.00.
Old Jun 2, 2008 | 12:12 PM
HondaMechanic's Avatar
Code #5 is "angle sensor system - motor lock" ... When you installed the new angle sensor did you pre-load it ..
Old Jun 2, 2008 | 01:15 PM
tnabb's Avatar
Yes I did. I put it on and gave it about a 1/4 turn or so I could feel the spring pressure.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Wooodyii2
Nov 16, 2020 07:14 PM
tiresharkdbb
Sep 3, 2017 02:06 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
hoopduerr
Jun 2, 2015 09:01 AM
