help with '01 rancher
Old Jun 14, 2008 | 10:15 PM
embler's Avatar
Default help with '01 rancher
its a rancher 350 with es. I'm having problems with it shifting. it'll shift fine when it isn't running. once I start it up, if I shift into first it'll die. after it dies, I have to rock it a little and then it'll shift back to neutral. any adjustments I can do? any other advice?
Old Jun 15, 2008 | 01:11 PM
Blazer19's Avatar
The clutch may be sticking and dragging down the motor. Crank the engine and with that little tool that comes with the ES hold up on the shifter like it would be going into 1st and rev the engine a little. Dont let it pop down or it will go into 1st. By holding it up and reving a little if your clutch was stuck it will free it.
Old Jun 15, 2008 | 01:29 PM
embler's Avatar
what is the tool? I don't know too much about honda's and it belongs to a friend of a friend. is it just like a shift lever?
Old Jun 16, 2008 | 05:27 PM
Crank Shaft's Avatar
The tool is in the rear storage compartment and is a flat stamped emergencey shifter.
Old Jun 16, 2008 | 08:15 PM
embler's Avatar
thanks. I looked for the tool but it wasn't there so I just used a wrench. seems to shift a lot better now. I'm going to clean up the electrical connections tommorrow. thanks again for the help
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
rgjackson
Sep 17, 2015 11:21 AM
Elkaholic
Sep 6, 2015 02:44 PM
