500 Foreman Electric Shift
Old Jun 16, 2008 | 11:38 AM
JeffinTD's Avatar
Default 500 Foreman Electric Shift
^ HondaMechanic is amazingly helpful. We are lucky to have him, and people like him here...
Old Jul 4, 2008 | 05:02 PM
foreman man's Avatar
i had the same problem with mine now its fixed after a took it to the shop
after thati havent had any problem with it
Old Jul 4, 2008 | 05:14 PM
wilber15's Avatar
I had the same problem with mine(less then 15 hours on it). I took it to the shop under warranty and they never ran the pin point test. well after buying the manual and removing the front rack and fenders, I ran the test. After removing the green connector on one side of the ECM, i disconnected it and found water and corrosion within the connector. I figured that from pressure washing it after every ride, i forced water into the connector thus causing the Code "2" I was getting for the upshift/downshift. I cleaned it and put dielectric grease in every connector on the wheeler and have had no problems since.
If you can look under the left front fender, directly below the handle bar next to the ECM is the green connector that goes directly from the ES shifter. Pull it off it's mount and disconnect the harness. If there's ANY water in there, thats your problem...... good luck!!
mark23
Oct 1, 2015 09:57 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
