300ex supposed tobe this hot?
Old Jun 19, 2008 | 04:09 AM
Matt1980's Avatar
Default 300ex supposed tobe this hot?
so hot i cant touch the dip stick and i checked oil and their wasnt any metal chips so is this normal or somthing wrong
Old Jun 19, 2008 | 09:48 PM
rvessar's Avatar
I have 2 300exs they get pretty hot .What kind of riding were you doing ,go slow or fast they are air cooled.
Old Jun 20, 2008 | 04:18 PM
Matt1980's Avatar
i was just putting around in the trails for 30 minutes
Old Jun 20, 2008 | 06:06 PM
Blazer19's Avatar
You need to get the temp checked. Cheap way is get a old candy thermometer. But you were the one that said it smoked a towel and that has to be above 300
Old Jun 21, 2008 | 04:43 PM
Matt1980's Avatar
it doesnt smoke at all and it runs great
Old Jun 21, 2008 | 05:42 PM
rvessar's Avatar
If you have to big of a main jet in carb it can run to hot also
Old Jun 22, 2008 | 01:53 AM
Matt1980's Avatar
my 300ex is completely stock so the jets are stock but i was going to get an hmf sport series exhaust for it and change the jetting but i am not sure i want to because its so dang hot. i have had about five people tell me that my 300 being that hot is normal and about five tell me its going to blow up if i keep riding it so i dont know what to do
Old Jun 22, 2008 | 12:12 PM
rvessar's Avatar
I just rebuilt one of mine with high comp piston and wanted to make sure oil pump was working good so I took off valve adjustment cover and started it to make sure it was oiling good it should spit out oil if it is .Like I said before I have two 300exs and we were riding yeasturday and when we got done you cant put your hand on bottom case they are to hot.Hope this helps.If you have a candy term. check temp and I can check mine and let you know
Old Jun 22, 2008 | 06:25 PM
300exStroked's Avatar
every 300 i know runs pretty hot.. one way to solve this is put an oil cooler on it.. get an old tranny cooler (small one) and rig it up to the oil pump line that runs to the rockers. seen plenty of people doing that.. if you purchase one they are a bit pricey. not too much work and a few bucks and you can make one work.
buddieboy
Dec 9, 2016 05:50 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
