Rancher help
Old Jun 21, 2008 | 11:40 AM
MadRebel's Avatar
Default Rancher help
Hi folks, my cousin has a 2005 Rancher and is having starter problems. When the key is turned on and he hits the starter button, nothing but a click. Once in a while it will start but most of the time nothing. He's thinking it's the starter but I was leaning more towards a bad battery. He rides it several times a week so it hasn't been setting up.
Any ideas and suggestions are appreciated.
Old Jun 21, 2008 | 12:18 PM
HondaMechanic's Avatar
Use a voltmeter , put the ( + ) positive on the starter post and put the ( - ) negative on a good ground (battery negative post) turn on the key and push the start button if the voltmeter reads 12v (or battery voltage) the starter peobably needs new brushes ..
Old Jun 21, 2008 | 02:01 PM
MadRebel's Avatar
I see I can get one on ebay for about $75.00 plus shipping, would it be cheaper to just buy a replacement or have his rebuilt?
Thanks for the help!
Old Jun 21, 2008 | 04:27 PM
HondaTech68's Avatar
if you have 12 volts at the battery and your hearing the relay still click the next thing to check is power at the starter its the big wire that attaches to the starter with a 10 mm nut put the positive on that nut and the negative on the frame or engine from your volt meter if your getting 12 volts there its more than likely your starter motor
Old Jun 21, 2008 | 05:03 PM
MadRebel's Avatar
The relay is clicking and it is getting 12v to the starter, guess I'll be ordering a starter off of ebay for him. Thanks for the help guys!
Old Jun 21, 2008 | 05:14 PM
I would test it first , and myself i'd put brushes in it and clean the commutator bars but if you'd sooner get a new starter then that's the way to go ... We rebuild quite a few starters and it's not a hard job at all..
Old Jun 22, 2008 | 02:17 AM
420 Rancher's Avatar
Also check the cylonoid my friend has a 450 foremen and he rides in the water alot and the cylonid tends to go out alot that might be the problem but it could be alot of other things to
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
rgjackson
Sep 17, 2015 11:21 AM
Elkaholic
Sep 6, 2015 02:44 PM
