rubicon code 5
Old Jun 23, 2008 | 04:32 AM
Big Red 01's Avatar
Default rubicon code 5
i have a problem with a 2001 rubicon i went in deep water but not the first time and later in the day it went in limp mode and gave me the code 5 it stuck in first gear and when in rev. it stumbles, pops, with no power any help to point me in the right direction to fix prob. thank you
Old Jun 23, 2008 | 07:32 AM
HondaMechanic's Avatar
Code #5 is an angle sensor (motor lock) code , Its probably moisture I would check/clean/grease the couplers for the ECM , angle sensor and shift control motor first ... Here are the Hondamatic component locations & couplers ..
Old Jun 23, 2008 | 09:36 PM
Big Red 01's Avatar
i checked the conectors everything is dry and clean, cleared codes and checked control motor and it works checked the reduction gear is free turns both ways started engine to see if it done anything but still not working but it gave the code 5 again.
Old Jun 25, 2008 | 01:30 AM
Big Red 01's Avatar
ok i took a chance and bought a new angle sensor and thank god it fixed the problem, i think i will try to stay out of the deep water from now on because the sensor ran me about $100.00
Sw00p
Sep 24, 2015 02:50 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
