Weak ling on the Gorilla winch
Old Jul 4, 2008 | 01:24 PM
action450s's Avatar
Default Weak ling on the Gorilla winch
<div class="FTQUOTE"><begin quote>Originally posted by: jrafter
customer service is great......you can sit it the the mudhole and wait for the UPS GUY everytime you use it.</end quote></div>
Agreed, for the few extra $$$ I'd rather have a decent winch and get home at a decent hour instead of speanding the nite in the woods cursing on plastic gears and faulty parts.
Old Jul 9, 2008 | 07:57 AM
Hondaddy's Avatar
got my parts from gorilla yesterday, and put the winch back together. went out to the same hill i broke it on, and winched up and down it, 8 times, using about 40 ft.of the cable. no problems. i had to winch out of the creek, so i winched up, and down it, 4 times no problem. all this winching took place in about 20 minutes. the motor was hot, but not hot enough you couldn't keep your hand on it. both these hills are steep enough you can't ride up them, well the first one you can, if you can get a really good running start. anyway, will do more testing this weekend. also, all these pulls were straight line, no block and tackle were used.
Old Jul 10, 2008 | 11:11 AM
1M800's Avatar
I just sent my Gorilla back 2 days ago. It didn't last one ride. We will see what happens!
Old Jul 10, 2008 | 12:52 PM
Hondaddy's Avatar
what broke on yours?
Old Jul 10, 2008 | 12:59 PM
  #15
TLC's Avatar
TLC
The odd thing is Gorilla makes the strongest axles and CV joints,you would think there winches would be the same.
Old Jul 10, 2008 | 01:01 PM
  #16
1M800's Avatar
I'm not sure I didn't tear it apart. I just took it off and sent it back. But it wouldn't hold. When I was winching it would release the spool (it would slip) I'm not sure if that made sense? But as I used it, it got worse and worse, by the end of the ride it would barely move my wheeler. It mostly made a horrible noise while sometimes grabbing and sometimes slipping. Hopefully I will get a good one! I am a little nervous about putting it back on. I have a 2000 lb Warn on my wifes 500 and she will never use it, so I might put the Gorilla on it and the Warn on my 700.
ultangler
Nov 30, 2024 01:35 AM
Johnny Mac
Aug 15, 2019 03:13 PM
cboler9
Sep 24, 2015 08:35 PM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
